Nowlflr
Mar 25, 2020Aspirant
Constant drops and disconnects XR700
Nighthawk XR700 with the same issue as many other posts - constant drops/disconnects from internet. I’ve read through many other posts with varying solutions such as: firmware update needed firmware...
Mar 26, 2020Guru - Experienced User
Do you mean it won't stay connected to auto update?
You can manually update it.
directly connect to your modem from your pc and download the firmware file. then follow the manual firwmare update procedure from the manual. After the update, factory reset, and manually re-install.
Netduma-Fraser
Mar 26, 2020NetDuma Partner
When it disconnects do all devices get disconnected or is it just wired devices or wifi devices for example? When it happens go to the interface using the LAN IP and then go to System Information - In the Internet Status panel does it say connected or disconnected?
- wafublokeApr 22, 2020Guide
I am having a nightmare too!
As mentioned by the poster above, constant drop outs both 2.4Ghz and 5Ghz, wired and WiFi. I've tried everythng from firmware, rebooting, unplugging components... everything. Gone back to my ISP modem and working fine.
My dropouts happen every 30-50 seconds and last for a few seconds. I get about 58Mbs download once minute then I'm down to 0.
- Netduma-FraserApr 22, 2020NetDuma PartnerCould you try removing devices 1 by 1 and see if the dropouts continue? I've seen it before where 1 device has caused the issue for some reason.
