Blake2022
May 30, 2022Tutor
Constant multiple issues with brand new XR1000
Only have had the router for less than a month and almost every day I have to reboot the router because wifi has stopped working for devices in the house from phones to ipad to computer. Ethernet wor...
Netduma-Fraser
May 30, 2022NetDuma Partner
Are you using Smart Connect? How are you rebooting the router exactly - by unplugging the power?
Blake2022
May 30, 2022Tutor
No smart connect and I reboot it from going into routerlogin
- Netduma-FraserMay 30, 2022NetDuma PartnerDoes it happen for both 2.4 & 5GHz? Could you provide the log file from the System Information page please when it happens? That will give us a better idea of what could be happening.
- Blake2022May 30, 2022Tutor
Wont be home from work until 6pm central time. Ill post on here. thank you for responding.
- Blake2022May 31, 2022Tutor
here is the log
- Netduma-FraserJun 02, 2022NetDuma PartnerI can't see anything in the logs specifically that would have caused a disconnect unfortunately. After a factory reset for example, what settings do you change right away?
