Blake2022
May 30, 2022Tutor
Constant multiple issues with brand new XR1000
Only have had the router for less than a month and almost every day I have to reboot the router because wifi has stopped working for devices in the house from phones to ipad to computer. Ethernet wor...
Blake2022
May 30, 2022Tutor
No smart connect and I reboot it from going into routerlogin
Netduma-Fraser
May 30, 2022NetDuma Partner
Does it happen for both 2.4 & 5GHz? Could you provide the log file from the System Information page please when it happens? That will give us a better idea of what could be happening.
- Blake2022May 30, 2022Tutor
Wont be home from work until 6pm central time. Ill post on here. thank you for responding.
- Blake2022May 31, 2022Tutor
here is the log
- Netduma-FraserJun 02, 2022NetDuma PartnerI can't see anything in the logs specifically that would have caused a disconnect unfortunately. After a factory reset for example, what settings do you change right away?
