vanderboegh
Feb 27, 2018Tutor
Correct Setup
We own the XR500 , one SX10 and two S8000. I have all of our Ethernet cords from our house and our garage hooked into the SX10 which then connects to the XR500.. Two of those cords are coming from th...
Netduma_Jack
Feb 27, 2018NetDuma Partner
So your setup is Modem / Router > SX10 > Nighthawk XR500 > Two S8000's and all devices? The recommended setup for the Nighthawk XR500 is Modem > Nighthawk XR500 > (Switches if required) > All Devices. If this setup is functioning correctly (i.e you are receiving your full speeds and have an open NAT) then you should have the correct physical setup and the Xr500 will be able to control all of your devices. Please let us know if you are having any issues with your current setup and we'll be happy to help.
- vanderboeghFeb 27, 2018Tutor
The recommended setup for the Nighthawk XR500 is Modem > Nighthawk XR500 > (Switches if required) > All Devices..... This is the setup that I have with normal operating mode turned on in your switches. So this is the correct setup?
- Netduma-FraserFeb 27, 2018NetDuma PartnerIn that case yes that is the best setup. We (Netduma) only cover the XR500 as we made DumaOS which is the software used. We can only advise on that specifically and broader use of switches as a whole.
From there I would recommend running the tours on QoS & the Geo-Filter by clicking the ? icon in the top bar next to the logos to get to grips with how the features work.
Generally we recommend Anti-Bufferbloat set to 'Always' with 70% sliders for both upload & download. Then on the Geo-Filter select your device and choose the profile of the game you're playing to set up the map settings accordingly.- BretDFeb 27, 2018Administrator
Speaking for myself, I have a similar setup to the OP.
>Cable modem > XR500 (To SX10 Switch) > SX10 Switch (To PC, Ethernet Switch, ReadyNAS , etc. ) > Additional Switch (Xbox, TV Etc.)
I've had fantastic performance in this situation.
