Billybudz420
Feb 07, 2018Apprentice
Correct Xbox one X settings
I bought xr500 and see no difference when gaming. I also cant seem to get roblox to work correctly on my xbox one x... says no connection to sever. My daughter is begging me to fix this. Any one able ...
Netduma-Fraser
Feb 07, 2018NetDuma Partner
Hi Billy, firstly make sure all devices are connected to the R1 so that it can control your network effectively.
Set your Anti-Bufferbloat to 'Always' and put the download & upload sliders to 70% each. Also ensure DumaOS Classified Games is enabled under Traffic Prioritization.
What games are you playing on the Xbox? Add your Xbox to the Geo-Filter under the devices panel and leave it on filtering mode. Then set your home location to where you live and start with a 1000km radius. I haven't played Roblox before so if you have a problem connecting then switch the Xbox to Spectating Mode instead and you should be able to connect without issue.
I would also recommend going through the tours for QoS & the Geo-Filter. To do this click the ? icon next to their titles in the top menu bar beside the logos. This will get you to grips with how the features work.
