Billybudz420
Feb 07, 2018Apprentice
Correct Xbox one X settings
I bought xr500 and see no difference when gaming. I also cant seem to get roblox to work correctly on my xbox one x... says no connection to sever. My daughter is begging me to fix this. Any one able ...
Feb 07, 2018Guru - Experienced User
What is the Mfr and model# of the ISP modem? Stand alone or built in router?
I would set IPv6 to disable if it's not already, Also try disabling beamforming and MIMO to disable as well.
Try setting NAT FILTER to Open instead of secure.
- Billybudz420Feb 07, 2018ApprenticeI am using the netgear cm1000 mode.I have the sliders at 70%. Do I need to add the xbox or just leave duma games or whatever it is checked only. The other question is where should I put the bandwidth for the xbox. I was wondering why disable wifi features its hard wired..... and why ipv6?
- Netduma-FraserFeb 07, 2018NetDuma Partner
You don't need to add the Xbox manually, the Xbox is covered by DumaOS Classified Games so you can just leave that enabled. Depends on your total bandwidth but I would give it at least 1mbps upload.
Not all devices support IPv6 so when connecting over the internet to servers/people that could have a negative impact - never seen it myself but IPv4 would prevent that. Plus QoS on the XR500 works for IPv4, we're adding IPv6 functionality in a later software. IPv6 doesn't give you a better gaming experience either so there is no harm disabling it.- Netduma-FraserFeb 12, 2018NetDuma PartnerHi Billy, just checking to see how you're getting on after my suggestions. Are you still experiencing the issues you were before?
