Billybudz420
Feb 07, 2018Apprentice
Correct Xbox one X settings
I bought xr500 and see no difference when gaming. I also cant seem to get roblox to work correctly on my xbox one x... says no connection to sever. My daughter is begging me to fix this. Any one able ...
Cdealva
Nov 22, 2018Initiate
Just bought nighthawk x10 9000. This does not play well with xbox one x. Drops connection, looks for connection, can't connect, appears to be constantly roaming or rebooting. Any help would be appreciated. Have used smart connect on and off, tried to speed test said no Internet connection. Opened nat filtering,
Netduma_Jack
Nov 23, 2018NetDuma Partner
Hi there - I think you need to post in a different forum. This is dedicated to the Nighthawk Pro Gaming range (the XR500 and XR700).
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
