Moisture
May 11, 2020Tutor
Crazy Ping Spikes in Online Games
Hello! For the past few weeks I have been experiencing crazy ping spikes. The strange thing is that it only happens on games. It has never happened before also. I ran games on two different computers...
- May 20, 2020That will be down to the ISP then, you've done what you can on your side now with that percentage but that issue is something you'll need to try and get the ISP to help with. It may help to say that your job requires low latency and that it is interfering with it, they may be more amenable.
Moisture
May 16, 2020Tutor
For both I was downloading a game. The one with QoS enabled was the optimal QoS settings.
Netduma-Fraser
May 16, 2020NetDuma Partner
As in you used 70/70? It needs more tweaking to find the percentage that lowers that ping more and to eliminate those spikes.
- MoistureMay 16, 2020Tutor
Is it going to need to be higher or lower do you think? And yes I used 70/70.
- Netduma-FraserMay 16, 2020NetDuma PartnerAs I mentioned in my suggestion, use different percentages while downloading and running PingPlotter to find the percentage that lowers the ping the most and keeps it the most stable. It could be either, it really depends on your individual connection - for some people it is higher, for others it is lower.
- MoistureMay 18, 2020Tutor
I went up by intervals of 10%, and nothing changed. I still got a similar amount of ping spikes.
- Netduma-FraserMay 18, 2020NetDuma PartnerTry intervals of 5% surrounding the percentages that were the best of a bad bunch.
- MoistureMay 19, 2020Tutor
Hi, sorry for the late response. I changed it to 45% each and it definitely limited my spikes. I only spike about every 20 minutes. Is there anything else I can do to lower it? Thanks so much though.
- Netduma-FraserMay 20, 2020NetDuma PartnerThat's great! How much is the spike that you get every 20 minutes? You've probably optimized as much as possible, that might be due to ISP.
- MoistureMay 20, 2020Tutor
The spikes vary, but are usually from 200-1100 and last for around 10 seconds. On some games they are more frequent though.
- Netduma-FraserMay 20, 2020NetDuma PartnerThat is really high, does it happen directly connected to the ISP modem/router?
Yeah, It's also worse on some games.
- Netduma-FraserMay 20, 2020NetDuma PartnerThat will be down to the ISP then, you've done what you can on your side now with that percentage but that issue is something you'll need to try and get the ISP to help with. It may help to say that your job requires low latency and that it is interfering with it, they may be more amenable.
