Moisture's avatar
May 11, 2020
Crazy Ping Spikes in Online Games
Hello! For the past few weeks I have been experiencing crazy ping spikes. The strange thing is that it only happens on games. It has never happened before also. I ran games on two different computers...
  • Netduma-Fraser's avatar
    Netduma-Fraser
    May 20, 2020
    That will be down to the ISP then, you've done what you can on your side now with that percentage but that issue is something you'll need to try and get the ISP to help with. It may help to say that your job requires low latency and that it is interfering with it, they may be more amenable.
