Booklover
Feb 23, 2022Aspirant
Currently using XR500. Do I need to upgrade?
Hello. I am looking to replace my current router with a router that is made for gaming on two Xbox ones. *We have two Xbox ones [will get the new Xbox when I can find them] hardwired to the curre...
Booklover
Feb 24, 2022Aspirant
Thank you.
I've done a little bit of tinkering with the QOS and ping. I've set my ping no higher than 60 and selected the call of duty.
I've set the Xbox ones to get more of the traffic.
I do need to read more about the DumaOS to try to setup the router better.
Netduma-Fraser
Feb 24, 2022NetDuma Partner
We can't really advise based on feel or hitmarkers but on ping which is what the router can actively lower so if you're still having issues do let us know some more details on that. Great reading above to get to grips with the router, also there are ? icons on every panel on the interface that will give you additional information.
