MdoggTV
Sep 01, 2021Guide
CXR700 duma os 3.0
hey guys I was wondering is there a release yet for the xr700 ? also i am having some dhcp issues were mine is not giving ip's to wifi devices. unless i set them all as static.just wondering is this ...
MdoggTV
Sep 01, 2021Guide
hey the beta i heard there was one but I am not using it yet, were would i find this at ? also is there many known bugs with it ? just wondering how stable it is
Netduma-Liam
Sep 01, 2021NetDuma Partner
You can find it here:
https://www.dropbox.com/s/1yxwq75k726hkgw/XR700-V1.0.1.34_Dumaos3.0_6.img?dl=0
It's pretty good actually, there have been the odd issue reported but none that are limited to this beta and none than everyone experienced as far as I'm aware.
Be sure to factory reset after installing it, also if you do run into any issues you can always downgrade back to the firmware you're on now.
- MdoggTVSep 01, 2021Guide
Hey,
thanks for that :) i will install that shortly if i do need to downgrade would you have the image i need ?
- Netduma-LiamSep 01, 2021NetDuma Partner
Sure thing, the latest full release firwmare can be found here:
https://www.netgear.com/support/product/XR700.aspx#Firmware%20Version%201.0.1.44
amazing thanks for the help :)
