Masonstorm
Jun 14, 2018Follower
D7800 x4s modem only
Trying to set up xr500 with d7800 x4s which has modem only facility - if I have two netgear products on same network how do I access www.routerlogin.net which one will it default to cannot find any do...
BIG_DOG
Jun 14, 2018Luminary
if you have set it to modem only mode and connected it to XR500 then you can try using 192.168.1.1. routerlogin should be accessible for xr500 and to access your d7800 you may have to connected wired directly from that to your pc in order to take it out of modem only mode if you have to.
Netduma-Fraser
Jun 14, 2018NetDuma Partner
Further to what Big Dog has said the XR500 would have detected the interface IP clash and given the XR500 a different IP to be accessible from. Accessing using the IPs exclusively will get you to the correct interface.
