Rick6922
Feb 01, 2019Luminary
deafult WAN settings
I changed some of the boxs in WAN setup to get it to work on new FW. I just got the 10gtek so I want to switch them back, does any one know the deafult settings for xr700 ?
- Feb 05, 2019The only thing that is ticked by default I believe is IGMP proxying
Netduma_Jack
Feb 05, 2019NetDuma Partner
Set it to dynamically get a WAN IP from the ISP (in >Settings >Internet Setup)
- Rick6922Feb 05, 2019Luminary
I didnt change anything there. it was in WAN setup .
if you go to WAN setup theres 5 boxs that can be checked. I changed them to get the router to stop losing internet conection before I bought the 10gtek . I dont rember what they were before. lol i need some one with the xr700 that hasnt changed them to look at what boxs are checked.
- Netduma-FraserFeb 05, 2019NetDuma PartnerThe only thing that is ticked by default I believe is IGMP proxying
thank you.
