Cujoma's avatar
Cujoma
Guide
Feb 09, 2020
dedicated servers inside my geofilter
Hey everyone. Hopefully a quick question for you. I am playing cod modern warefare on my xbox one. It is in filtering mode. Everything seems to be working good. My question is .... When i have a dedicated server pop up inside my geo filter safe circle, should i be clicking allow on it in the "auto ping" section? i have done that with a few and they move over into my "Allow and Deny" section. I just want to be sure im doing that correctly. I would rather keep connecting to those servers if possible. But since doing it, the game seems to take a long time to find a match.
Thanks in advance!!
  • No you don't need to do that, as they're already in your radius they've already been allowed. The allow/deny section is for permanently allowing/denying connections which would apply regardless of your filter settings.
1 Reply
