Cayde-6's avatar
Cayde-6
Tutor
Oct 10, 2020
Destiny 2 on PS4
Okay so what i know is that Bungie recentely has released on console something that let the routers works bad. Also, i know that for resolve this issue you need to update the firmware to 3.0 (beta), ...
  • Netduma-Fraser's avatar
    Oct 11, 2020
    You are right in that they have released updates, however it is not as simple as doing a cloud update as normal. It will require actual changes to the Geo-Filter, we are still investigating but this will take some time.
