bacevedo
Oct 29, 2019NETGEAR Employee Retired
Developer Blog 1: The Future of DumaOS: Version 3.0
Last year we released our first major update for DumaOS, Milestone 1.3. You guys loved it, so we quickly got to work on the next milestone, packing it full of features to make your Nighthawk P...
Netduma-Fraser
Dec 10, 2019NetDuma Partner
The Geo-Filter does get you the closest server currently, you may be experiencing issues with mislocated servers but we'll be doing a cloud update soon to resolve this so you may find that improves then. The Device Manager issue we are aware of so that will be fixed. Not sure I understand the Geo-Filter issue, this may be Ping Assist connecting you to games outside your radius. You won't be able to force yourself to be host - this would also be considered cheating. You can only force the server you connect to not the players, you can't influence other peoples connections. You can set the Ping Assist to lower than 30 but depending on your location, base ping etc you may not get a game under this.
YT-xIndicaxHigh
Dec 11, 2019Aspirant
How is force host cheating! Me always being the host of the games makes my ping lower. So I just dont know how its cheating when I'm making my latency even lower because I'm the host of the game!
Another thing Ping Assist doesn't work on PC for Modern Warfare. Just went to a lobby today an I have it set to 30ms with no fast search an i got into a lobby with 70ms with Filtered mode on. At a 311 Radius. Sense seattle is my closest server. That need a fix as well if that can be done with this update. I never use fast search unless I'm playing a old game like Advanced Warfare. I have it toggled off for Modern Warfare. So I wanted to notify you that. I know there's a COD server in Seattle which I'm a hour away from.
- Netduma-FraserDec 11, 2019NetDuma PartnerForcing yourself to be host gives you an advantage over everyone else, it's also not possible to do as it's primarily a server based game anyway. Did you set Ping Assist prior to loading up the game or while you were on the game? If you do it while the console is off and then try does it work correctly?
- YT-xIndicaxHighDec 11, 2019AspirantThe advantage for a force host option is lower ping means your shots register before his does that's a good advantage. Why should my KD or Overall stats suffer because they cant afford good speeds or have a good internet setup. Like I pay for equipment to get my ping as low as possible so I can have a edge against players. Force host is not cheating in my book an should be a future feature for DumaOS to all P2P games like Call of Duty. COD Matchmaking isnt the best anyways. All itd do is always make you the host of the game which would = best ping in the lobby because you be the one hosting the game. which is a great advantage an definitely ain't cheating because your trying to accomplish a faster connection & responsiveness Ingame. I personally dont like losing to someone with high ping or a bad network setup. Its hella unfair & frustrating.
Not trying to bash people with this but if your internet cant handle a game like COD which every lobby is competitive anyways. Do not play the game. Because I dont want to be the one dying from you because I cant hit you because your lagging so bad on my screen. Delt with this too many times on MW2 an MW3.
I hope you understand my point man & not trying to bash people but honestly Call of Duty is not for casual people anymore an its common sense to not try to play a game if your internet is not sufficient to handle it.- Netduma-FraserDec 11, 2019NetDuma PartnerI do understand your point but if we were to allow people to force themselves to become host every time then you could use the router to cheat by fluctuating the connection so much making others lag. This happened on Halo 2 way back on the day and was a widely used cheating technique. CoD uses dedicated servers anyway so this wouldn't be possible but I understand why you'd want it.
