bacevedo
Oct 29, 2019NETGEAR Employee Retired
Developer Blog 1: The Future of DumaOS: Version 3.0
 Last year we released our first major update for DumaOS, Milestone 1.3. You guys loved it, so we quickly got to work on the next milestone, packing it full of features to make your Nighthawk P...
DRU732
Jan 02, 2020Tutor
100% agreement with OlegP
I've had the XR500 since it came out and the only meaningful Duma update I see is the ability to view my Network Map as a table vs the tree map ... which is a visual mess if you have many computers/phones/people/iot/smarthome devices. I've pursued both Duma forums and Netgear forums ... and there is a lot of finger pointing back and forth. It's not clear who owns the underlying router functions
This router might be good in a house 10-20 devices, but more than that and sometimes the visual interface makes everything more difficult.
- Lookup a device by MAC addresss? nope
 - Export a device list? nope
 - Sort by MAC address or IP? nope
 - Updated device types? (camera, iot, SmartHome, switch/hub/extender ...) nope
 - Device names that stay tied to MAC address?  nope
- Devices that I have named, frequently return as "unnamed device"
 - Usable logging?  nope
- If "Marking a marked device" is a dev message not meant for me (the user), give me a checkbox to filter it out
 - Seriously 90% of my logs are "Marking a marked device", should I have to export the file to excel and manually filter it out to figure out if I am getting DDOS/intrusion traffic?
 - Ability to monitor OpenVPN connections to the router?  nope
- Router doesnt show connected devices
 - IP range is outside of DHCP, and non-configurable
Netduma-Fraser
Jan 02, 2020NetDuma Partner
Some of the things you've mentioned are possible such as sort by MAC/IP and some will be possible in future updates. It's important to remember that we wanted to create an easy to use gaming router, things like logs do not affect gameplay performance at all. More niche/usual router functions like that can come later based on customer feedback which we listen to constantly.
