bacevedo
Oct 29, 2019NETGEAR Employee Retired
Developer Blog 1: The Future of DumaOS: Version 3.0
 Last year we released our first major update for DumaOS, Milestone 1.3. You guys loved it, so we quickly got to work on the next milestone, packing it full of features to make your Nighthawk P...
May 26, 2020Guru - Experienced User
Never seen an inconvience with my XR router pre and current CD19 events. Not sure why current events would cause problems with your router. Yes CD19 is causing slow downs for support. Goes for any router mfr and there support. Its effecting everything.
Did you even try reverting back FW versions or go with initial first version FW? Seems like more troubleshooting would be needed to really figure out where your problem is other than being inconvienced by the slow down which no can help you with currently. :smileytongue:
Netduma-Fraser
May 26, 2020NetDuma Partner
I'd suggest signing up for the beta here so that you can be one of the first to see if it resolves your issues: http://www.netgearinnovation.com/dumaos-beta/index.html
- KostasKtm83Jul 16, 2020StarHi guys!!
I am still stuck with the invitation for the R1 beta!! I am waiting over one week to change that to receive the link for the XR 500 that I have... Can you please do something???- Netduma-FraserJul 16, 2020NetDuma PartnerWe can't swap the invites but we've put your name forward, you just have to wait for the invite now.
- basilverthornJul 16, 2020Tutor
Have we started the XR700 beta yet? Just curious.
