bacevedo
Oct 29, 2019NETGEAR Employee Retired
Developer Blog 1: The Future of DumaOS: Version 3.0
Last year we released our first major update for DumaOS, Milestone 1.3. You guys loved it, so we quickly got to work on the next milestone, packing it full of features to make your Nighthawk P...
IRONEAGLE777
Oct 30, 2019Initiate
An auto forwarding function screen for multiple Consoles would be a game changer! Port settings get over lapped too easily in the UPnP screen resulting in a console getting kicked to moderate NAT or STRICT NAT. Then the user has to uncheck the Auto UPnP box ☑ to reset the ports numbers and restart the consoles. Having the this service would make it a new industry standard! Management and releasing frustrating NAT issues is what everyone is looking for. - IRONEAGLE777
raghavan
Dec 23, 2020Aspirant
Will the power / hardware of the R1 be maxed out & at its limits with all these updates? I only ask because I’ve seen concerns in the past with the current DumaOS & R1, possibly taxing it too much. Any talk of upgrading the hardware/router itself?
Thanks!
- Netduma-FraserDec 23, 2020NetDuma Partnerraghavan We're certainly putting it through its paces yes but we won't do anything for the R1 version that will unnecessarily put strain on it to the point where it would affect your connection. We can't upgrade the R1 hardware specifically as we don't own the hardware. However, we released a successor to the R1 - the R2, which is more powerful, optimized for DumaOS 3.0 and owned by us.
- scotja50Jan 04, 2021Aspirant
How can you say that? this whole project is just the router software version of cyberpunk at this point. wasted all your customers time and money.
- Netduma-FraserJan 04, 2021NetDuma Partnerscotja50 what are you referring to exactly? Are you having a specific issue we can help with?
