MyuuKun
Dec 17, 2018Tutor
Device Manager / Network Monitor Not showing all data
I just purchased and set up the XR500, I meticuously added each device and re-named them both using the web app and the phone app (they have different options for setting connection description - the...
- Dec 18, 2018
XR500 V2.3.2.40 - shows the latest firmware.
After a soft reboot (through the mobile app) it seems to have corrected the online/offline mix of devices and they are now showing usage on the monitor so it looks like it's all working correctly after a soft reboot.
Thank you
Netduma_Jack
Dec 18, 2018NetDuma Partner
They will show as online on the Device Manager if they are using data. If they're not, they will appear idle to the router. To test if this is the reason, try puttng data through one of the 'offline' devices. Does it then show as online?
MyuuKun
Dec 18, 2018Tutor
No, it does not show them online when they are clearly consuming data. Must be a firmware bug.
