MyuuKun
Dec 17, 2018Tutor
Device Manager / Network Monitor Not showing all data
I just purchased and set up the XR500, I meticuously added each device and re-named them both using the web app and the phone app (they have different options for setting connection description - the...
- Dec 18, 2018
XR500 V2.3.2.40 - shows the latest firmware.
After a soft reboot (through the mobile app) it seems to have corrected the online/offline mix of devices and they are now showing usage on the monitor so it looks like it's all working correctly after a soft reboot.
Thank you
MyuuKun
Dec 18, 2018Tutor
No, it does not show them online when they are clearly consuming data. Must be a firmware bug.
Netduma_Jack
Dec 18, 2018NetDuma Partner
Ok - are you on the latest firmware 2.3.2.40? https://kb.netgear.com/000060464/XR500-Firmware-Version-2-3-2-40
Please upgrade to it if you have not already.
And could you list out some/all of the devices that refuse to appear online?
Thanks.
- MyuuKunDec 18, 2018Tutor
Thank you
- Netduma_JackDec 19, 2018NetDuma Partner
Good job. Thanks for letting us know.
- jeremyg237Jan 16, 2019Luminary
I have to reboot my router everytime I want the xbox to show in the device manager.
