NikciD
Dec 15, 2019Tutor
Device Manager / Network Monitor Not showing all data
I seem not seeing my devices online when they're being used. Specifically, my XBox doesn't show online, daughter's phone doesn't show online, and my cameras don't show connected. I have the latest fir...
NikciD
Dec 15, 2019Tutor
That was a typo. I meant rebooting.
Netduma-Fraser
Dec 17, 2019NetDuma Partner
How were you doing the reboots? Via the interface or by pulling the power/using power switch? Are you using the Smart Connect WiFi feature?
- PsycholotronJan 11, 2020AspirantIs there any new updates on this problem being fixed. It’s been an ongoing issue for months now. I regret switching to netgear. I’ve had nothing but problems. Setting icons and descriptions saves and then resets to default after having to reset router because no devices are found. Constant packet loss and devices disconnecting for no reason from WiFi. When I pay for an item, I typically expect a finished product. Not something that’s still in beta testing.
- Netduma-FraserJan 11, 2020NetDuma PartnerThere are no updates on it that I am aware of, I'm not sure when Netgear want to release another firmware. You shouldn't be having any packet loss/wifi disconnections, how are you measuring this? Make a new topic and we can see how we can help.
