downindm's avatar
downindm
Device Manager Not Showing Connected Device
I have a Raspberry Pi connected wirelessly to the router.  For some reason I am unable to see the device in the Device Manager.  Actually, I am able to see it as offline - but only with a Wired MAC address.  The Pi does have a WiFi connection as it is reporting it.  And oddly enough, when I went to Settings > LAN Setup on the router to reserve an IP for it, it did show up there with the connected IP address and MAC.  I went ahead and assigned it a static address and applied it (waiting for it to disconnect everything and reconnect).  Still, it's not showing up in Device Manager.
  • If you do something on the Pi to initiate some internet traffic then look on the Device Manager do you see it appear as online then?
    If so if the router doesn't detect any data passing through the device it will appear as offline until it detects traffic.
    • downindm's avatar
      downindm
      No, I am able to play a video over the network that is streaming from the Pi and it is still not showing as being connected or having an IP address in the device manager.  Could this be due to it connecting to the network through my range extender (a Linksys AC1200 MAX Wi-Fi Gigabit Range Extender / Repeater - RE6500)?  I have other devices (such as a FireTV that connect through it as well and they show as online).
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Yes it could quite possibly be that. If you connect it directly does it behave as expected?
