downindm
Apr 29, 2018Aspirant
Device Manager Not Showing Connected Device
I have a Raspberry Pi connected wirelessly to the router. For some reason I am unable to see the device in the Device Manager. Actually, I am able to see it as offline - but only with a Wired MAC a...
Netduma-Fraser
Apr 29, 2018NetDuma Partner
Okay interesting! If you could possibly capture the traffic of the Pi using something like PingPlotter we can try to determine why that is. Yes I tested the EX8000 recently which does exactly that - unsure if it would show the Pi online as we (Netduma) don't have one to test with.
downindm
Would be happy to. I downloaded PingPlotter on my Mac which is connected to a LAN port on the XR500. What do I need to do? Have never used this software before. Or do I need to find something like it that runs from the Pi (it's a model 3B+)?
- Netduma-FraserApr 29, 2018NetDuma PartnerPingPlotter or a similar program if you can find it should run on the Pi itself. Then just capture the traffic and use the Pi how you normally would.
