heroxoot's avatar
heroxoot
Apprentice
Mar 23, 2019
Device manager not updating.
I have an XR450 (basically a XR500) and I have issues with my device manager (network map). When I disconnect a device or just shut it off, it still claims it is online.  For example, my GF had not been over for a week and it still said her phone was connected to the 5G wireless signal. It does this on both wired and wireless devices. It only becomes an issue when a device won't appear as online, as it screws with Geofilter when that happens. Like say, my PS4 is offline right now and I rebooted the router. It will currently shows as an offline device, but when I turn it on, it does not move into the online devices. I would like to not have to reboot my router every time I want to turn something on/off to remove/add it to my devices.
  • What firmware version are you on? I assume the latest .40? In which case did it only occur when upgrading to this firmware? If so downgrade to .32, do you still see the issue?
    • heroxoot's avatar
      heroxoot
      Apprentice
      It started on .32 I believe. I didn't notice it at first and when I did .40 had come out. In reality it fixed it for a while but after the router has been running so long it quits working for me in the device list.  I only care because if I turn on a console and it was showing as offline, it won't move to online status and thus Geo Filter does not function.
      • heroxoot's avatar
        heroxoot
        Apprentice
        As of now my Nintendo Switch for example shows as offline and will not move to Online devices even tho I'm using it online right now. And thus Geofilter does not populate for games.
