Raansu
Apr 09, 2020Tutor
Device manager reporting incorrectly/Changing link speeds on port.
So my issues are two fold here. 1.) Device manager is reporting incorrectly. Its stating ports that are empty are in use and showing devices offline when they are online. I've tried factory resettin...
Raansu
Apr 14, 2020Tutor
I use cat6 cables. I'm not sure about my roommate. He was the one only getting 100Mbps, but he gets the full 500 when I plug everything back into my router from my ISP. If I don't use my ISP router and plug the connection directly into my nighthawk I only get 100Mbps across the board, which lead me originally to having put my isp router into bridged mode.
I find it kind of odd that such an expensive router can't control port speeds manually though.
Netduma-Fraser
Apr 14, 2020NetDuma Partner
Disable QoS completely from the Anti-Bufferbloat option menu, do the speeds return then?
- RaansuApr 16, 2020TutorI will give the qos setting a shot when the new firmware comes out. Thanks for the help.
