Raansu
Apr 09, 2020Tutor
Device manager reporting incorrectly/Changing link speeds on port.
So my issues are two fold here. 1.) Device manager is reporting incorrectly. Its stating ports that are empty are in use and showing devices offline when they are online. I've tried factory resettin...
Netduma-Fraser
Apr 14, 2020NetDuma Partner
Regarding the first issue I believe this is something we're aware of so will be fixed in the next firmware. If you downgrade then this should be resolved but you would miss out on security fixes. There are no port options for the router, they will run up to 1000Mbps depending on what ethernet cables are plugged in. What ethernet cables are you using, are they Cat5e or above?
dpweller
Apr 15, 2020Guide
Great advice. Downgrade but then security is compromised. SMH.
- Netduma-FraserApr 16, 2020NetDuma PartnerThat's why I mentioned it, I'm not recommending it but stating what is missed out by doing so.
