alexrw's avatar
alexrw
Follower
Mar 02, 2018
Device Types & DUMAOS
Does DUMAOS treat devices any differently based on the set Device Type in the Device Manager?  Will there be more options available?
It would be nice to have:
- Speaker
- IoT
- Light switch / power
- Thermostat
  • Hi Alex, at the moment the only way it treats devices differently is if you have one of the console device types when adding it to the Geo-Filter it will automatically set it to filtering mode. All other devices will be set to spectating mode depending on the service you choose (don't get a service choice for consoles).
    We will definitely be adding more device types like that! We need to be able to classify them. If you have those devices and would like to help with that please PM me.
  • Add in Chromecast and Google Home also. I've got those set under Computer at the moment.
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      Great we can add those as well. If you want to help us classify it please PM me.
      • DrPatchy80's avatar
        DrPatchy80
        Initiate
        I would also like to know what to classify Chromecasts and iPads/iPhones that are used to stream. I want to make sure streaming doesn’t interfere with my gaming? Which is why I bought this router??
