cjwaeltz
Sep 26, 2022Follower
Devices dropping from XR500 Router
Hello ... I'm having some issues with a couple of devices, and thought I'd ask the community for thoughts. I changed to a new ISP in March 2022 , and per their recommendation switched to a Netg...
Sep 26, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Please set the default IP address range on the router to 192.168.1.100 to .200 then see what happens?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Set 20/40Mhz Coexistence to 40Mhz only.
Test with Beamforming and MIMO are enabled.
