cjwaeltz
Sep 26, 2022Follower
Devices dropping from XR500 Router
Hello ... I'm having some issues with a couple of devices, and thought I'd ask the community for thoughts. I changed to a new ISP in March 2022 , and per their recommendation switched to a Netg...
Netduma-Fraser
Sep 27, 2022NetDuma Partner
Most likely they are devices that only support 2.4GHz and don’t work well with Smart Connect, disable that, connect them directly to 2.4GHz and they should work.
