Adrian126
May 01, 2021Follower
Devices not connecting to the 5G band on the XR500
Hello, I changed my ISP modem yesterday, I have a spectrum cable connection. They gave me a ET2251 technicolor modem. I went through an extensive process in getting it set up, had to call and eve...
Netduma-Fraser
May 04, 2021NetDuma Partner
Try a reset as above first, if that doesn't work then in Advanced Wireless settings, disable the wifi radios fully, then apply, then reboot the router from the interface and then wait 2 minutes then enable the wifi again then apply, then reboot and see if it works properly then.
