csimpson4
Sep 29, 2020Aspirant
DHCP Constant Renewing Issue
My XR700 is contantly renewing DHCP leases and many of my wireless devices lose Internet access. They work when I set a static IP for the devices. I've rebooted and updated to firmware V1.0.1.34. I'v...
Netduma-Fraser
Sep 29, 2020NetDuma Partner
There will be DHCP fixes in the beta firmware, I can't say exactly when it will be available but we are working very hard to get it out as soon as possible. Are you using Smart Connect for WiFi? It could be part of the problem that switching between bands causes some disconnects so perhaps disabling this could help.
- csimpson4Sep 29, 2020Aspirant
Thanks for the reply. Not using smart connect. It just started "out of the blue", we've had the router since May.
Best Regards,
Chris
- Netduma-FraserSep 29, 2020NetDuma PartnerWhat is your XR connected to exactly a modem or router?
