Koz1614
Aug 29, 2022Tutor
DHCP constantly renewing XR500
Hi, Does anyone know why I am constantly seeing the DHCP new event/new lease? This happens multiple times per hour, everyday. I recently upgraded to firmware V2.3.2.134 which seemed to mostly re...
Koz1614
Aug 30, 2022Tutor
Hi,
I have about 10 - 15 devices at any given time. Is it normal to see the renewed lease like this all the time?
Heres the latest logs. Connection dropped off at 8:55pm EST tonight. Since upgrading to firmware .134 the connection seems more stable, but I thought I recall reading something about prior versions with DHCP lease issue?
DumaOS] DHCP lease change., Tuesday, August 30, 2022 17:00:13
[DumaOS] DHCP new event., Tuesday, August 30, 2022 17:00:13
[DHCP IP: 192.168.1.14] to MAC address 4a:26:59:cd:c0:7c, Tuesday, August 30, 2022 17:00:13
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 17:00:11
[DumaOS] DHCP new event., Tuesday, August 30, 2022 17:00:11
[DHCP IP: 192.168.1.14] to MAC address 4a:26:59:cd:c0:7c, Tuesday, August 30, 2022 17:00:11
[Time synchronized with NTP server] Tuesday, August 30, 2022 16:58:37
[DumaOS] The selected theme does not exist: 'default', Tuesday, August 30, 2022 16:57:59
[DumaOS] Theme path does match manifest 'default', Tuesday, August 30, 2022 16:57:59
[DumaOS] Cloudsync Themes result 'false','All mirrors are down', Tuesday, August 30, 2022 16:57:59
[DumaOS] Config Changed: DumaOS_Public_IP, Tuesday, August 30, 2022 16:57:52
[DumaOS] Marking device that is marked 192.168.1.19 19 7., Tuesday, August 30, 2022 16:57:40
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 16:57:40
[DumaOS] DHCP new event., Tuesday, August 30, 2022 16:57:40
[DHCP IP: 192.168.1.19] to MAC address 6e:1a:95:06:29:fd, Tuesday, August 30, 2022 16:57:40
[DumaOS] Marking device that is marked 192.168.1.19 19 7., Tuesday, August 30, 2022 16:57:37
[DumaOS] Marking device that is marked 192.168.1.19 19 7., Tuesday, August 30, 2022 16:57:36
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 16:57:35
[DumaOS] DHCP new event., Tuesday, August 30, 2022 16:57:35
[DHCP IP: 192.168.1.19] to MAC address 6e:1a:95:06:29:fd, Tuesday, August 30, 2022 16:57:35
[admin login] from source 192.168.1.18, Tuesday, August 30, 2022 16:57:30
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 16:57:21
[DumaOS] DHCP new event., Tuesday, August 30, 2022 16:57:21
[DHCP IP: 192.168.1.4] to MAC address 98:29:a6:8b:b8:61, Tuesday, August 30, 2022 16:57:21
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 16:57:20
[DumaOS] DHCP new event., Tuesday, August 30, 2022 16:57:20
[DHCP IP: 192.168.1.4] to MAC address 98:29:a6:8b:b8:61, Tuesday, August 30, 2022 16:57:20
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 16:56:42
[DumaOS] DHCP new event., Tuesday, August 30, 2022 16:56:42
[DHCP IP: 192.168.1.7] to MAC address 92:7f:01:01:b6:2d, Tuesday, August 30, 2022 16:56:42
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 16:56:27
[DumaOS] DHCP new event., Tuesday, August 30, 2022 16:56:27
[DHCP IP: 192.168.1.17] to MAC address 00:1a:13:b1:7f:1c, Tuesday, August 30, 2022 16:56:27
[DumaOS] DHCP new lease allocated., Tuesday, August 30, 2022 16:56:24
[DumaOS] DHCP new event., Tuesday, August 30, 2022 16:56:24
[DHCP IP: 192.168.1.18] to MAC address 6c:40:08:97:24:a8, Tuesday, August 30, 2022 16:56:24
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 16:55:59
[DumaOS] DHCP new event., Tuesday, August 30, 2022 16:55:59
[DHCP IP: 192.168.1.11] to MAC address 3c:22:fb:68:9d:4c, Tuesday, August 30, 2022 16:55:59
[DoS Attack: Ascend Kill] from source: 75.75.75.75, port 53, Tuesday, August 30, 2022 16:46:19
[DoS Attack: SYN/ACK Scan] from source: 91.218.213.49, port 8000, Tuesday, August 30, 2022 16:43:42
[DumaOS] DHCP new lease allocated., Tuesday, August 30, 2022 16:21:29
[DumaOS] DHCP new event., Tuesday, August 30, 2022 16:21:29
[DHCP IP: 192.168.1.17] to MAC address 00:1a:13:b1:7f:1c, Tuesday, August 30, 2022 16:21:29
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 15:45:40
[DumaOS] DHCP new event., Tuesday, August 30, 2022 15:45:40
[DHCP IP: 192.168.1.11] to MAC address 3c:22:fb:68:9d:4c, Tuesday, August 30, 2022 15:45:40
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 15:39:37
[DumaOS] DHCP new event., Tuesday, August 30, 2022 15:39:37
[DHCP IP: 192.168.1.7] to MAC address 92:7f:01:01:b6:2d, Tuesday, August 30, 2022 15:39:37
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 15:11:06
[DumaOS] DHCP new event., Tuesday, August 30, 2022 15:11:06
[DHCP IP: 192.168.1.13] to MAC address 76:47:93:42:5c:bd, Tuesday, August 30, 2022 15:11:06
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 15:10:57
[DumaOS] DHCP new event., Tuesday, August 30, 2022 15:10:57
[DHCP IP: 192.168.1.13] to MAC address 76:47:93:42:5c:bd, Tuesday, August 30, 2022 15:10:57
[DoS Attack: TCP/UDP Echo] from source: 183.136.225.9, port 8088, Tuesday, August 30, 2022 14:18:12
[DoS Attack: ACK Scan] from source: 64.141.207.59, port 443, Tuesday, August 30, 2022 13:47:51
[DoS Attack: SYN/ACK Scan] from source: 40.113.105.173, port 443, Tuesday, August 30, 2022 13:45:43
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 13:35:26
[DumaOS] DHCP new event., Tuesday, August 30, 2022 13:35:26
[DHCP IP: 192.168.1.7] to MAC address 92:7f:01:01:b6:2d, Tuesday, August 30, 2022 13:35:26
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 13:35:23
[DumaOS] DHCP new event., Tuesday, August 30, 2022 13:35:23
[DHCP IP: 192.168.1.7] to MAC address 92:7f:01:01:b6:2d, Tuesday, August 30, 2022 13:35:23
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 13:35:22
[DumaOS] DHCP new event., Tuesday, August 30, 2022 13:35:22
[DHCP IP: 192.168.1.7] to MAC address 92:7f:01:01:b6:2d, Tuesday, August 30, 2022 13:35:22
[DoS Attack: SYN/ACK Scan] from source: 195.208.6.1, port 53, Tuesday, August 30, 2022 13:13:36
[DumaOS] The selected theme does not exist: 'default', Tuesday, August 30, 2022 12:57:59
[DumaOS] Theme path does match manifest 'default', Tuesday, August 30, 2022 12:57:59
[DumaOS] Cloudsync Themes result 'false','All mirrors are down', Tuesday, August 30, 2022 12:57:59
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 12:50:56
[DumaOS] DHCP new event., Tuesday, August 30, 2022 12:50:56
[DHCP IP: 192.168.1.3] to MAC address be:a5:11:12:47:50, Tuesday, August 30, 2022 12:50:56
[DumaOS] Marking device that is marked 192.168.1.19 19 7., Tuesday, August 30, 2022 12:43:11
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 12:43:11
[DumaOS] DHCP new event., Tuesday, August 30, 2022 12:43:11
[DHCP IP: 192.168.1.19] to MAC address 6e:1a:95:06:29:fd, Tuesday, August 30, 2022 12:43:11
[DoS Attack: SYN/ACK Scan] from source: 91.218.213.49, port 8000, Tuesday, August 30, 2022 12:39:12
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 12:29:14
[DumaOS] DHCP new event., Tuesday, August 30, 2022 12:29:14
[DHCP IP: 192.168.1.14] to MAC address 4a:26:59:cd:c0:7c, Tuesday, August 30, 2022 12:29:14
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 12:29:12
[DumaOS] DHCP new event., Tuesday, August 30, 2022 12:29:12
[DHCP IP: 192.168.1.14] to MAC address 4a:26:59:cd:c0:7c, Tuesday, August 30, 2022 12:29:12
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 12:29:10
[DumaOS] DHCP new event., Tuesday, August 30, 2022 12:29:10
[DHCP IP: 192.168.1.14] to MAC address 4a:26:59:cd:c0:7c, Tuesday, August 30, 2022 12:29:10
[DoS Attack: SYN/ACK Scan] from source: 50.204.152.175, port 80, Tuesday, August 30, 2022 11:45:51
[DoS Attack: SYN/ACK Scan] from source: 20.55.17.177, port 3389, Tuesday, August 30, 2022 11:43:34
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 11:43:27
[DumaOS] DHCP new event., Tuesday, August 30, 2022 11:43:27
[DHCP IP: 192.168.1.3] to MAC address be:a5:11:12:47:50, Tuesday, August 30, 2022 11:43:27
[DoS Attack: SYN/ACK Scan] from source: 3.134.137.253, port 443, Tuesday, August 30, 2022 11:37:39
[DoS Attack: ACK Scan] from source: 136.22.131.22, port 443, Tuesday, August 30, 2022 11:30:18
[DoS Attack: ACK Scan] from source: 136.22.131.22, port 443, Tuesday, August 30, 2022 11:29:48
[DoS Attack: ACK Scan] from source: 136.22.131.22, port 443, Tuesday, August 30, 2022 11:29:17
[DoS Attack: ACK Scan] from source: 136.22.131.22, port 443, Tuesday, August 30, 2022 11:28:47
[DoS Attack: SYN/ACK Scan] from source: 185.26.185.82, port 9443, Tuesday, August 30, 2022 11:20:16
[DoS Attack: SYN/ACK Scan] from source: 195.208.6.1, port 53, Tuesday, August 30, 2022 11:16:27
[DoS Attack: NULL Scan] from source: 81.70.198.235, port 39131, Tuesday, August 30, 2022 10:59:33
[DumaOS] DHCP new lease allocated., Tuesday, August 30, 2022 10:37:37
[DumaOS] DHCP new event., Tuesday, August 30, 2022 10:37:37
[DHCP IP: 192.168.1.16] to MAC address 00:17:88:6e:84:22, Tuesday, August 30, 2022 10:37:37
[DoS Attack: SYN/ACK Scan] from source: 13.225.103.57, port 443, Tuesday, August 30, 2022 10:37:04
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 10:09:59
[DumaOS] DHCP new event., Tuesday, August 30, 2022 10:09:59
[DHCP IP: 192.168.1.12] to MAC address 08:d2:3e:88:70:4d, Tuesday, August 30, 2022 10:09:59
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 10:09:58
[DumaOS] DHCP new event., Tuesday, August 30, 2022 10:09:58
[DHCP IP: 192.168.1.12] to MAC address 08:d2:3e:88:70:4d, Tuesday, August 30, 2022 10:09:58
[DoS Attack: ACK Scan] from source: 162.241.216.182, port 443, Tuesday, August 30, 2022 09:45:38
[DoS Attack: SYN/ACK Scan] from source: 40.113.105.173, port 443, Tuesday, August 30, 2022 09:41:30
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 09:40:41
[DumaOS] DHCP new event., Tuesday, August 30, 2022 09:40:41
[DHCP IP: 192.168.1.14] to MAC address 4a:26:59:cd:c0:7c, Tuesday, August 30, 2022 09:40:41
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 09:28:28
[DumaOS] DHCP new event., Tuesday, August 30, 2022 09:28:27
[DHCP IP: 192.168.1.3] to MAC address be:a5:11:12:47:50, Tuesday, August 30, 2022 09:28:27
[DumaOS] DHCP lease change., Tuesday, August 30, 2022 09:08:23
[DumaOS] DHCP new event., Tuesday, August 30, 2022 09:08:23
[DHCP IP: 192.168.1.7] to MAC address 92:7f:01:01:b6:2d, Tuesday, August 30, 2022 09:08:23
[DumaOS] The selected theme does not exist: 'default', Tuesday, August 30, 2022 08:57:58
[DumaOS] Theme path does match manifest 'default', Tuesday, August 30, 2022 08:57:58
[DumaOS] Cloudsync Themes result 'false','All mirrors are down', Tuesday, August 30, 2022 08:57:58
[DoS Attack: SYN/ACK Scan] from source: 64.20.54.10, port 443, Tuesday, August 30, 2022 08:56:42
[DoS Attack: SYN/ACK Scan] from source: 35.201.87.6, port 5222, Tuesday, August 30, 2022 08:47:43
[DoS Attack: SYN/ACK Scan] from source: 35.201.87.6, port 5222, Tuesday, August 30, 2022 08:47:26
[DoS Attack: SYN/ACK Scan] from source: 35.201.87.6, port 5222, Tuesday, August 30, 2022 08:47:18
[DoS Attack: SYN/ACK Scan] from source: 35.201.87.6, port 5222, Tuesday, August 30, 2022 08:47:14
[DoS Attack: SYN/ACK Scan] from source: 35.201.87.6, port 5222, Tuesday, August 30, 2022 08:47:12
Netduma-Liam
Aug 31, 2022NetDuma Partner
They do seem a little more frequent than we'd expect, I'd suggest following the steps in my last post and see if the disconnections stop after that.
- Koz1614Aug 31, 2022Tutor
Do you know what actually triggers these frequent events? I will try your suggestion
- Netduma-LiamAug 31, 2022NetDuma Partner
In theory, it's a genuine DHCP lease renewal. By default the lease time is (I believe) 12 hours, which means it'll re-negotiate a new lease every 6 hours.
Is there still some issue with this in the latest V2.3.2.134 firmware? I know I was reading about this issue with prior releases
