Tylerleepart
May 27, 2021Aspirant
DHCP Issues
For starters; this is an on going issues with this router since day one. I originally fixed by downgrading the firmwareto 2.3.2.22, however, I'm now using hybrid VPN, so I needed to update to the la...
Netduma-Fraser
May 27, 2021NetDuma Partner
I'd recommend you try upgrading to the latest beta version that you can find here: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/bd-p/en-home-beta-npg-duma it does have some fixes for issues around DHCP and it's something the NG team are still looking into
