Johnny4091
Jan 13, 2020Aspirant
DHCP ISSUSE
I have a Night Hawk Pro gaming router and the DHCP is saying that my ISP is 10. 0. 0. 1 but it's really posed to be 192.168.1.254 how do I get it changed I have AT&T fiber optic Please someone help!...
Netduma_Alex
Jan 14, 2020NetDuma Partner
I assume that 192.168.1.254 is the gateway IP of your ISP router? is your XR500 connected to your ISP router?
Johnny4091
Jan 14, 2020Aspirant
Yes it is. I also factory rest it to and the DHCP is Still showing 10.0.0.1 .
Thank you for ur response.
- Netduma-FraserJan 14, 2020NetDuma PartnerDid you set the .254 IP yourself? It's likely doing that to prevent conflicts, what is the LAN IP of the XR router?
- Johnny4091Jan 14, 2020AspirantNo that's the AT&T DHCP I was told by AT&T
There's a picture of the LAN SETUP- Netduma-FraserJan 14, 2020NetDuma Partner10.0.0.1 is the LAN IP of the XR router, that is completely normal, it has nothing to do with the IP of the AT&T router, that IP won't have changed.
