Johnny4091
Jan 13, 2020Aspirant
DHCP ISSUSE
I have a Night Hawk Pro gaming router and the DHCP is saying that my ISP is 10. 0. 0. 1 but it's really posed to be 192.168.1.254 how do I get it changed I have AT&T fiber optic Please someone help!...
Johnny4091
Jan 14, 2020Aspirant
Yes it is. I also factory rest it to and the DHCP is Still showing 10.0.0.1 .
Thank you for ur response.
Netduma-Fraser
Jan 14, 2020NetDuma Partner
Did you set the .254 IP yourself? It's likely doing that to prevent conflicts, what is the LAN IP of the XR router?
- Johnny4091Jan 14, 2020AspirantNo that's the AT&T DHCP I was told by AT&T
There's a picture of the LAN SETUP- Netduma-FraserJan 14, 2020NetDuma Partner10.0.0.1 is the LAN IP of the XR router, that is completely normal, it has nothing to do with the IP of the AT&T router, that IP won't have changed.
- Johnny4091Jan 14, 2020AspirantI have a Tablo DVR and I can't access it on my firestick because it has a IP address of 192.168. 1. 28 but my firestick has an IP address of 10.0.0.24 when I call Tablo they said that the reason why my firestick and Tablo are not responding to each other is because of two different IP addresses now the Tablo is hooked up to the AT&T modem so is the Nighthawk so it should have a IP address of 192.168.1. ??? there is picture down below from the fire stick of the Gateway IP address the modem Gateway IP address is : 192.168.1.254
