Compoza_
May 19, 2025Luminary
DHCP on XR500
Could you guys give me a step-by-step process to set up DHCP manually with reserved IP adress. Because the issue with dhcp renewal lease time on my XR500
Compoza_
that was not entirely I was looking for. You have to disable the dhcp and set the range and all that? I just wanna know and in what order.
Netduma-Fraser
May 19, 2025NetDuma Partner
Change the range to start at .50, set all your reservations first, giving them IPs between .2 - .49 then once you've done them all you can disable DHCP
