bdkdozer
Aug 03, 2020Guide
DHCP Renewing issues
Router keeps renewing DHCP almost hourly: [DumaOS] applying qos for zone lan, Monday, August 03, 2020 15:09:55 [DumaOS] config write 'com.netdumasoftware.devicemanager.database', Monday, August 03, ...
- Aug 05, 2020That's great to hear, thank you for the update!
bdkdozer
Aug 05, 2020Guide
It's been a full day and NO Resets. I did a hard reset on the router not in the routers OS. Did the basic unplug and plugin one at a time and all is good. I did go through all the settings to see if I would notice any setting changes and one thing that did stand out was for some reason the Disable Port Scan and DoS Protection in WAN Setup was checked and in the ipv6 was set at Auto now at disable. So with those 2 things different and off all is stable and I can now print, Raid WoW, and stay connected. Thank you for your help and let all remember ... when in doubt just unplug it, reset it and start from scratch.
Netduma-Fraser
Aug 05, 2020NetDuma Partner
