Tonufun's avatar
Tonufun
Follower
Mar 30, 2021
Directv HR24 won’t connect to XR1000 router. Says device not found.
I have Directv HR24 with the connected home adapter. I now have a Netgear Nighthawk XR1000. I cannot connect my Directv to the router. I also tried using a Directv CCK & still no luck. Everything else in the house connects. I do not get the opportunity to enter ssid or password. It just says device not found.
     Directv says this is a router issue, probably being a "gaming" router the ports won't allow Directv to access the Ethernet cable.
1 Reply
  • In WAN Settings on the router, try toggling IGMP Proxying and then connect the device and see if it works. If not disable QoS from the Congestion Control 3 line option menu and try then.
