downindm
Jul 19, 2019Aspirant
Disable 5G Radio on XR500
How exactly would I go about disabling the 5G radio in my XR500 router?
1 Reply
- Netduma_AlexNetDuma Partner
Go to Settings > Setup > Wireless Setup. Disable Smart Connect, and then you should be able to disable the 5GHz network.
