yksi
Oct 21, 2018Tutor
Disconnect on New DHCP Lease Allocation (Ethernet)
So this issue has been going on for literally since I bought this router, 8 months ago. Every single time my router needs to allocate a new DHCP lease, which for some reason is every 24 hours because...
Netduma-Fraser
Oct 22, 2018NetDuma Partner
Hi yksi, sorry to hear you're having this issue. I have PM'd you with a beta firmware to try. Please see if this resolves your issue.
- yksiNov 04, 2018Tutor
So it worked for a week or so and just now I disconnected again on the DHCP new lease... not sure what else I can do about it
- nytiger73Nov 06, 2018Star
I had the same issue. I ended up returning the router. The basic function of a router is to share an internet connection and allocate IP addresses. When it can't even do that correctly, there is an issue. I wanted to like this router, it has some awesome features. But until these DHCP features are solved, I wouldn't recommend this router. I went and hooked my R8000 back up.
- FURRYe38Nov 07, 2018Guru - Experienced User
Whats your IP address pool size set for?
Try setting it for 192.168.1.100 to .200.
Have you set up any IP address reservations for your devices?
- yksiNov 07, 2018Tutor
I'll give that a try.
I haven't tried reserving IPs - didn't know you could do that; I thought making a static IP was the same thing. I'll do that too.
