yksi
Oct 21, 2018Tutor
Disconnect on New DHCP Lease Allocation (Ethernet)
So this issue has been going on for literally since I bought this router, 8 months ago. Every single time my router needs to allocate a new DHCP lease, which for some reason is every 24 hours because...
yksi
Nov 07, 2018Tutor
I'll give that a try.
I haven't tried reserving IPs - didn't know you could do that; I thought making a static IP was the same thing. I'll do that too.
Nov 07, 2018Guru - Experienced User
Setting IP address reservations is done ON the router. Static IP addresses are set ON devices. These need to be out side of the routers default IP address pool however.
