-Donovan-
Jul 04, 2019Luminary
Disconnected from LAN
I recently upgrade my XR500 for a XR700. I was hopping not getting any Disconnected from LAN while I’m playing at Street Fighter V (SFV) on my PS4 Pro because every time I get kick out from the game ...
Jul 04, 2019Guru - Experienced User
I have not noticed this issue with xbox. I have two xbox consoles on line. No disconnections whilie gaming.
Wonder if this maybe a PS issue.
Do you have IP address reservatsions set for your PS console ON the XR router?
You might try this as well, set the default IP address pool size to 192.168.1.100 to .200. Then input a Static IP address ON the PS console thats outside of the new pool size. Input gatway and DNS as well ON the PS console. Let us know if this helps any.
- -Donovan-Jul 04, 2019Luminary
I aldready tested your suggestion but no success..
- FURRYe38Jul 04, 2019Guru - Experienced User
And this only happens on PS and this particular game? Any other games as well?
I only play a P2P game Street Fighter V on Playstation or on Steam. I only get a disconnected from LAN on the WAN Port when I'm playing on my PS4 Pro. I use my Steam account when I get banned for 24h with the Playstation account.
