SouthernGypsy
Jul 03, 2024Apprentice
Disconnected from Router after New Firmware and then RAP Not Loading after Reset?
XR1000v2 with the new Hot Fix software update... Ever since the new Firmware (xr1000v2 1.1.0.22_2.1.34) installation the other night my DumaOS keeps popping up a message "You have been disconnect...
Netduma-Fraser
Jul 05, 2024NetDuma Partner
How did you do the factory reset exactly? The device not found message indicates a factory reset needs to be done but in your case it doesn't seem to be clearing.
Go to the System Information page and then in the Rapp panel menu ≡ change the retries to 5, reboot from the interface, wait 4 minutes before accessing and see if it pages load better then.
