Pipodi
Sep 27, 2022Tutor
Discord traffic triggering Gaming Service on Traffic Prioritization
Hi guys, as title suggests, Discord triggers my Game Service rule for my gaming PC, so the entire network gets throttled to my Congestion Control slides (I'm actually on a 100/20MB connection, so...
Pipodi
Sep 27, 2022Tutor
I have disabled DumaOS Classified Games and Work At Home. I have created two Games Console rules, one for my Steam Deck and one for my PC, both set up as Games Console in Device Manager. I have no other rules.
Netduma-Fraser
Sep 27, 2022NetDuma Partner
Remove the Games Console rule for the PC and make an Advanced rule with the following information:
Source 1-65535
Destination 1024 - 49999
Protocol TCP/UDP
then see if it continues to prioritize games when needed and excludes Discord
Source 1-65535
Protocol TCP/UDP
- PipodiSep 27, 2022Tutor
It stays on even with Discord off, shouldn't be the range (at least for TCP ports, I think this will prioritize even browser traffic) smaller that that?
- Netduma-FraserSep 27, 2022NetDuma PartnerIt should be fine as the destination is above browser traffic ports but try this, we'll make two rules instead:
Source 1-65535
Protocol TCP
Source 444-65535
Protocol UDP- PipodiSep 29, 2022Tutor
Ok, this seems to work, but I've disabled the TCP rule because I've discovered that some clients (Battle.net, Steam) have active connections within that range, so they are triggering the TCP rule even in idle, without any game running. This should be fine too, because most of multiplayer packets are UDP if I am not mistaken.
