Kierok3
Apr 16, 2019Guide
Division 2 not connecting?
I have two ps4s on the same network. They both work fine with every game except the division 2. One of the PS4s works fine with several connection types(wired to modem, wired to XR500 wireless) but th...
- Apr 17, 2019Hey everyone! The issue was the date being wrong on the ps4! I hope this info can help someone else.
Netduma-Fraser
Apr 16, 2019NetDuma Partner
Have you got the Geo-Filter enabled for this game? If so then that is probably why. Disable the Geo-Filter and see if it works correctly. Our testing so far is showing that it may not be Geo-Filterable though we're still looking into it.
Kierok3
Apr 16, 2019Guide
Thanks for the response.
However, I do not have the Geo-Filter on. Do you have any other suggestions?
