Kierok3
Apr 16, 2019Guide
Division 2 not connecting?
I have two ps4s on the same network. They both work fine with every game except the division 2. One of the PS4s works fine with several connection types(wired to modem, wired to XR500 wireless) but th...
- Apr 17, 2019Hey everyone! The issue was the date being wrong on the ps4! I hope this info can help someone else.
Apr 16, 2019Guru - Experienced User
Try setting the NAT Filter to OPEN if you have two consoles online plaing the same game at the the same time.
- Netduma-FraserApr 16, 2019NetDuma PartnerAccording to online that error is usually caused by the game undergoing maintenance. Although a potential solution was a hard turn off of the console by holding down the power button until it turns off. Then unplug from the power for 30seconds and try again.
- Kierok3Apr 16, 2019GuideI tried it with my old router and it still does not work. I think I can rule out that the router is not the issue.
- Netduma_JackApr 17, 2019NetDuma Partner
Thanks for letting us know. Best of luck getting it fixed.
