ahettlin
Dec 11, 2018Aspirant
DNS Suffix
I had to replace my old router with DD-WRT because it was severely limiting my internet speed (by about 50%). I was debating between getting an XR500 or an X6S. I chose the XR500 because of what I ...
Netduma-Fraser
Dec 11, 2018NetDuma Partner
That feature is not available as far as I am aware. Settings is developed by Netgear so that would be one for them to do. I'll pass on your request to their team.
ahettlin
Ok. That makes sense. Thanks for passing it along. I suppose I'll have to figure out an alternative solution for now, or get a different router.
- Netduma-FraserDec 11, 2018NetDuma PartnerI'd suggest sticking with it for the QoS and Geo-Filter features, they will make a big difference to your gaming and general online experience.
- ahettlinDec 11, 2018Aspirant
I was able to get it working by keeping my old router with DD-WRT and using it for DHCP with the DNS suffix enabled there and disabling DHCP on the new router. It adds another device to the mix, but at least it works for now.
- Netduma_JackDec 12, 2018NetDuma Partner
Ok, well done for finding a workaround.
