Wyzfar
Jan 08, 2019Aspirant
DNS
Hello so when in command prompt when i ping the DNS 1.1.1.1 and 75.75.75.75, the results show in command prompt that 75.75.75.75 is faster by a few MS but in a benchmark shows 1.1.1.1 is faster but i...
Netduma-Fraser
Jan 08, 2019NetDuma Partner
The ping to your router/gateway is the fastest because it's in your local network, its the closest to you. Using the router as your DNS will just allow your router to use the ISP's standard DNS. DNS does not have an impact on your game experience so if just using the router as DNS gives you a good experience just stick with that.
Wyzfar
So essentially I am using my router as a dns server ?
- Netduma-FraserJan 08, 2019NetDuma PartnerYes and the router then uses the standard ISP DNS.
- WyzfarJan 08, 2019Aspirant
router uses my ISP default DNS, thus when i input my DNS as my router, i will be using the ISP default DNS but what if i dont input the DNS as my Router what if i input as an ip that is not being assigned or my router is using for instance 192.168.1.60
- WyzfarJan 09, 2019Aspirant
also is using the router as a DNS server faster then just inputing 1.1.1.1 since my router wouldnt be a DNS server then ?
