mikeyw978
Jan 14, 2020Follower
do i need a qos network switch to work with my XR500
Hello, Ive currenty got the nighthawk XR500 as i wanted a QoS router to enhance my gaming. ive just got a PC, im looking to buy a network switch so i can plug the ethernet from my xbox into it, then...
Netduma-Fraser
Jan 14, 2020NetDuma Partner
I would recommend you just get a basic/dumb switch as the XR500 will be handling the QoS. Adding something else that does its own QoS could you cause more issues.
